the snooper
getting older by the day
- Hull UK
If you've never had a problem before and the temp gauge has always hovered around the halfway mark I'd say the gauge is fine
Try running it longer if lower rad hose doesn't heat up eventually rad could be blocked
Through the rad? Hot in the top cooler out the bottom.feel ignorant asking...which way does the water circulate ?
any more info on pump removal please? got lots of bolts out the cam cover , engine mount off , pulley off , looks like all the bolts but it wont budge still so i packed up for the night ,
do i have to disturb the cam belt or what...looks like it ought to wiggle out
If top hose is that hot then the bottom hose should be hot so blockage of some description sounds likely remove hoses when cool and try flushing with hose pipetried a new stat now...passenger side /top hose is roasting hot and wobbling about ,other side is stone cold
does a blocked rad make any sense?
If it is blocked and has the crimped ends on I've removed the ends cleaned one out and refitted the ends with no.problems they just have a lot of bent over tabsthats tomorrows job cheers
Usually lack of changing the coolant over the yearsThe question would now be why did it get blocked on the first place
What you mean it isn't good for the entire lifetime of the car ?Usually lack of changing the coolant over the years
to never need changing.
