Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
If you have never opened the valve, I suggest you take it out side. It will mote than likely be rusted up, you might need a take the tap out and poke a hole throught the rust, make sure the pressure has been released from the tank.
Let it run for a bit on the grass, it will blow loads more crap out after the water has drained out. Clean the tap and refit
. opened the tap and nothing came out then there was a pop and the full lot came out
so now just open it empty. if nowt comes out I prick the tap with a bit of wire to check then turn the comp on and blow it out
