zeppelin builder
- peoples republic of scotland
best ones are enclosed filled with gylcol mix,works on the diamond wheel perimiter and tip is moved closer to center of spindle or away to alter angle , i get good results with a grinder but dont get caught on a big job doing it, elf n safety will nail you
It was horrible to set up, just a single dial and it stepped through as you turned, you then had to press to enter the setting it was at then turn dial to get the value you wanted then press again to accept then repeat again for the next setting, what made it even worse was there was a lag and often you thought you hadn't pressed the dial properly so pressed again which exited the setting and you had to go back. The screen was also poor, not much contrast and was quite hard to see which setting you were actually on. It did have a job store, not sure how many as I got that annoyed with it I never looked that far into the menu.
