Hey guys, just after some tips for cutting sheet metal straight with an angle grinder.Cut some 3mm sheet and was really disappointed and annoyed with myself started off Straight then went off wonkey.
Then run the plasma down a 3x2 for a straight cutBuy a plasma cutter![]()
Then run the plasma down a 3x2 for a straight cut![]()
Dont set yourself on fire from the sparks![]()
Don't set fire to the paraffin soaked rags you've been cleaning with either![]()
pulled the rags in middle got told that extinguisher wont work stamp stamp stamp until i pulled the trigger and it was out quickly been taking mickey out since then about itAnd remember the main thing.........let the tool do the work,not you![]()
