Yep i made a right mess of most of it. I've marked my first run where everything was going well. Think i lost my temper in the end and kept going although i'd contaminated the tungsten.I think you're arc length is too long and you're possibly contaminating the tungsten resulting in the brownish soot.
I have an esab warrior mask. I need to rig up some better lights as i cannot see anything until i start the arc and by then i've already messed it up.Are you using a decent mask?
You always weld to your thickest material.Does 130amps not seem a lot for that thickness? I don't do much steel, mainly stainless and Alu but even Alu I wouldn't expect to be as high as that.
Today I was welding 12mm stainless to 2" Sch40 pipe and I was only at 130amps.
In Dazs case that's 4mm.
120-130 amps is about spot on.
Its 1mm wall. Don't bother mocking anything up mate i just need more practice. Problem is i'm all over the place, aluminium one minute flat out like a lizard drinking, then on to some 0.5mm stainless. Then 1mm to 4mm with 1mm rod. Which was not too bad as i had to go quick.Is that tubing about 1.6mm wall?
If so I'm heading down the workshop to do some bits in a minute (yes I'm mad, -2 outside and unheated). I think I have some tune that size I could mock this joint up. You're tacks looks lovely so we know you've got enough heat there to start with
Really, must be down to different techniques or something.I'd probably be at more like 180 for that
Fillet and lapRough rule of thumb to work out where in the dial you need to be around isJust seemed high to me but as said very rarely do steel. Stainless is more fluid than steel so will likely need less current, certainly does with stick welding anyway.
Stainless 25 amps per 1mm
Steel 30 amps per 1mm
Alu 40 amps per 1 mm.
Work to your thickest piece.
Edit*. Joint type , part size, actual design. Etc all play a big role in how accurate and inaccurate that rule of thumb can be. It gets you in the rough ball park for most stuff.
Perhaps you travel slower than me. If that's the case at these current levels you will burn through thinner materials and likely undercut on thicker. Beware though welding too cold even if your fusing properly creates excessive heat input by going too slowly.These are way higher than I would start, maybe my technique plays a part, maybe machine, who knows. I do remember when I got the TecArc 251 I had to lower the current compared to what I had on the previous welders (Paweld 200amp analogue and crap LTS fire starter one) but the new Parweld seems to be consistent with the TecArc.
Looks good.
I'd be hotter (150 plus) and I'd be ploughing down it with a 3.2 filler. But that's the style I adopt for hefty plate. Especially an inside corner. It's a small coupon mind so 2/3 of the way down it I'd of backed off or speeded up
It looks tidy enough to me mate.Seems like it is all down to style/technique then, and I was going like the clappers from about half way
The pic is funny, kind of looks like big ripples at the start and smaller as I progress, must just be the camera angle or lighting as it is pretty even all the way.
