Looks like I can unscrew the relief screw fully and it will not be possible to go too far, so that is a relief (no pun intended
)Ummmmmm good Q.@Richard. whereabouts would I go about sourcing procon/roto-flo rebuild kits from? I have an old roto-flo that was being used for lpg transfer in a former life. If parts are cheap enough then I might have a look at sticking new guts in it.
Pics please hood of your connections. Now it's rare but sometimes there can be a bur in the head water jacket causing a blockage.I think it much more likely it is the torch but can't be 100% certain yet. Other people use the Quick Release fittings so it is unlikely them but I will see if I can find a way to hook it up without them later on, might not manage though as I am at home and do not have access to my lathe or other fittings.
I have just tried flow through the 6mm ID pipe, I fitted things up with the pressure gauge still in the loop and the pressure was 30 psi where when connected to the torch was 60psi. Flowrate was 2L in about 15 seconds so that would equate to about 8L/min.
So to me it looks like the torch is the culprit.
Also likely the Chinese pump would have been fine.
Also looks like even the central heating pump may have been adequate although obviously not as good as the Chinese and no where as good as the Procon.
I've been messing with the pressure sensor and flow sensor today, don't know if i can be bothered they are all wired up ready to go problem is the fittings, the pressure sensor is 1/8 npt and the flow sensor is 1/2 npt. Would like the flow sensor directly after the quick release return from torch and the pressure sensor T'd off the pump or before the quick release out to torch.I have been testing the extremely cheap Temp gauges I bought, have all 5 of them sitting here and they are all within 0.4 degrees of each other, one at 16.7 degrees, two sitting at 16.8, 1 at 17 and the last at 17.1 so they seem to at least tally with one another and likely are about right.
Should be fine for my needs as in reality +/- 5 degrees would be ok I would think.
Things like that are easy if you have a lathe as you can quickly make up adapters etc, without a lathe then you really need to try and find fittings that will suit. Suppose if you had the correct size taps you could just drill something like a lump of delrin and insert suitable fittings for your torch return and have the sensor screwed in.I've been messing with the pressure sensor and flow sensor today, don't know if i can be bothered they are all wired up ready to go problem is the fittings, the pressure sensor is 1/8 npt and the flow sensor is 1/2 npt. Would like the flow sensor directly after the quick release return from torch and the pressure sensor T'd off the pump or before the quick release out to torch.
