brockenhammer
- Freiburg, Germany
Hello again,
here are some news about my Hitachi catch.
The machine seems to work. I magaged to put a slower 20amps fuse into the workshop electric.
The problem was, that there is a very uncommon gasvalve build into the welder with a thread I don´t know and I have no gashose for. But I managed to start the machine. The fans run then for some seconds. Then they stop. When I push the pedal I could hear the ignition, and the gasvalves switching. Also the fans start to run then.
That all seems normal to me.
I measured the cutted cable in the back. There was 230V at the end. I guess that the former owner took that from somewhere in the machine to run the cooler from that.
Like I mentioned I carried to machine to a very good friend. He allready put a plug on the cutted cable ends. So It can be used again and can cause no harm when someone touches it.
He also tries to find the right threaded gas hose nuts. If thats not possible he wants to change the valve (he has some 24v valves in stock).
He also found a damaged cable at the remote interface. Maybe thats the reason for the uncommon remote with the 2 pots on the footcontrol.
We will find out.
There was a little problem with the cooler also.
When I pushed the start button, the relais worked, the fans started but the pump motor just made some noise. When I stop pushing the start button everything stops, and the relais doesn´t hold.
First I checked if it´s possible to move the motor by hand. It easily turned.
Then a friend measured the capacity on the electic pump motor.
I seems to be broken.
Therefore the motor doesn´t run. The preassure switch (which should protect the pump from running dry), which is mounted behind the pump, doesn´t switch and the relais doesn´t stay switched.
I bought a new capacitor and will put it on the motor when I´m back in the workshop in a few days.
Then it should work and I will build a nice little welder cooling cart hopefully from it.
Maybe out of alu to make the first useful aluwelds in my life.
Kai
We will find out.
Kai
