I find it weird you guys don't allow it in residential areas. I dunno how I'd make do without it...
For an ACDC??f £400. What have you got?
I'll give you that one but the gun is loaded and ready for anymoreAlthough, to be fair, if you have a corsa you'll be needing a welding set![]()
because the dataplate implied it would run on 230 volts at a lower maximum current?
.Acdc ??What if I said I just bought a 500amp Kemppibecause the dataplate implied it would run on 230 volts at a lower maximum current?
Because that's what I've done.
It was an impulse buy, I couldn't help myself
But I have enough change to buy a knackered Corsa.
It's a Kemppi MARC 500HF, the listing said ali welder but now I look more closely I can't see any switches to chose between AC and DC.Acdc ??
What would you expect to get out of it on a 16 amp supply?
Bet it's a beast.
.I'm starting to think so tooI'd say I think you have made a big mistake.
. If it comes to it I can stick it back on eBay
.One of these ...........It's a Kemppi MARC 500HF, the listing said ali welder but now I look more closely I can't see any switches to chose between AC and DC.
I've been a bit silly haven't I?
I'm hoping I can get around 80-100 amps, if not I could get a 32 amp feed fitted.
And yeah, it's a beast, but it came with a cooler so you'll like it.
I'm starting to think so too. If it comes to it I can stick it back on eBay
Yeah 240v 5million ampActually, you may have got lucky - there is a single phase version.
