Pollys13
- Wiltshire UK
Hi all,
I'm putting a magnetic lamp inside my blasting cabinet. Using digital calipers the lamps cable has an external diameter of 6mm.
The cabinet walls are made from 16 gauge steel -USA specification. I'm wondering which type, size of grommet I should use? I see there are tabular long grommets etc. Also what would be the correct size metal drilling bit to use to drill a hole in the wall of the cabinet for the matching size grommet?
An Ebay link whatever to identify the correct type of grommet would be much appreciated.
Cheers.
Peter.
Cheers.
Peter.
fftopic:Not sure what you blast in your cabinet or how course the grit is, but if it is steel you will probably find the light will be obscured with particles form the air sticking to the magnet and building up across the surface till the light is covered.
