thanks again pal , it will be fed from a phase converter .
is that the 240v single phase supply cable to converter?? 2.5mm or 4.0mm bestyour right , its the main feed to the supply box .
2.5mm static same as mineits a transwave 3hp static
will run 3hp ok I run my bridgie on it no probswill that run the bridgeport ok
All good then , i only want to get it running so i can investigate why the power feeds are not working .
