normspanners
flexible hydraulic? or nylon? (as per truck air lines)hard plastic 8mm pipe called
might have to be careful with QR if it is not connected or becomes disconnected it might damage pump seals
Well I have got it on the Kubota and it works - in a fashion. I will post a few pics tomorrow. I have got to run a drain from the cutter motor back to the hydraulic tank, unfortunately the one that's on their is not long enough. What is the hard plastic 8mm pipe called I've tried googling but too many hits. I was thinking of using a 1/4 quick connector to join the two - should stop it leaking oil when its disconnected.
Your right, I have enjoyed this one - Although it's taken a bit longer than a weekendSounds like a fun project.
forgive me if im wrong but didnt you say earlier that it was an 8mm pipe on the machine for the motor case drain?.I agree with you about the heat build up, luckily the Kubota has its own Aux hydraulic pump which is designed to run breakers/ water pumps etc up to 20lpm. Unfortunately the oil tank is quite small and I am not sure if it will act as a big enough heat sink, as I said earlier time will tell.
If I get another 4meters of pneumatic 8mm ID pipe I can get a push fitting to connect it to the existing pipe, what I need is a right angle fitting (lack of space) to connect it to the hydraulic tanks filler cap (dont want to drill the tank) Any suggestions anyone ?
I'll take a few photos tomorrow and post them up.you mentioned about the breakaway.
the way you have it was straight forward but as you say, now there is no breakaway, you could come up over the top of the cutter frame with some 10-12mm flat shaped like an elbow cumin out as far as the original ball eye that was on the arm and put a bolt in it, it will still flex enough on the breakaway to do, add a few washers if you want.
would that work for you?.
what kind of a fixing have you on the hog, is it designed to take something, i know you can get front attachments for them so there must be mounting points somewhere, its probably a frame that mounts to welded bushes down her a bit but im only guessing here.
your fairly ok with 8mm id but it ill only cost a few quid more to go to 10mm id, its what id use.Thanks for the input chaps, as usual I didn’t make myself clear. Whilst the existing hose is 10mm OD its actually 6mm ID. I though running it up to 8mm for another 3 meters would do the job – if you think that’s too fine I will run it up to 12mm with a 10m ID. The Top link was actually an afterthought (I like to call it plan B) as my original idea didn’t pan out quite the way I had hoped. I had based the original idea on this one but found it did not give me the adjustment I needed (well, not without a lot of work) Oh, and trying to fit the thing on your own was a nightmare.
