penfold
Ambassador plenipotentiary
- Argyll and Bute, God's own country.
Eh? Not to any greater degree than any other infernal destruction engine....And it produces Nitric acid out the exhaust.
i guess the most econoical way to get the littel bottel in the car filled is to get a bigger bottel off probaly air prducts or boc
Linde gases are the main Nitrous supplier, once again you're into cylinder rental territory similar to your argon bottle, you need to get through a lot of nitrous to warrant that,i guess the most econoical way to get the littel bottel in the car filled is to get a bigger bottel off probaly air prducts or boc
If your engineering is comparable to your spelling, not sure your 1000hp lump is going to live that long?
Easier said than done filling your own bottles from a big one, you'll need an expensive Cryo pump or there is another way where you freeze one bottle but cant remember the exact way its done.
there is no comparison. speling writeing isn't my strong point infact its my biggest curse allways has been and it's a lot better than it was, my enginnering on the other had is, if it needs to be written right it's written by someone else.
also you obviously cant read as where the hell did 1000 bhp come from i'm only considerign sparkeling a motor up into the mid 200's as that what i need from it, the blocks only eally good for 700 ish anyway if i went nuts i'd have to build from a diesel block to make the 1000 ponies and i aint doing that
That's a bit harsh.
A very good friend of mine has dislexia and has to use spell check on forums etc,Seems to me that if someone is looking for help, that they might bother to spend a couple of minutes installing a spell check?
There was a dyslexic comedian on the radio the other day, he was saying that the new smart phones 'learns' the words you use and adds them to the dictionary. The problem is his phone has now started suggesting dyslexic spellings, as in...A very good friend of mine has dislexia and has to use spell check on forums etc,
the problem for him is that it selects the word but deciding from the options often prooves difficult,
He does his best though...
