I use all three progressively.
I had always thought there were three holes for convenience but possibly also because it would also be better balanced with three holes rather than just one.
Exactly. Even if the chuck is worn only one is necessary, for two reasons - the first is that the scroll or ring is operating on all three jaws together, and the second is that any one of the three jaws is exerting pressure on the other two. It is impossible for one jaw to exert more pressure than any of the others (opposing forces and all that). It might be possible on a worn chuck that the drill (or workpiece on a lathe) will not be exactly centred, but how many of you clock a drill after you've chucked it? And on a lathe, if you want to centre something accurately you use a 4 jaw.Which ever hole you use (erm), only turns the same toothed ring though.
...Brace and Bits and wood working tools, hand tight only.
do we need to do a test on the tightening of drill chucks using a torque wrench on all 3 holes to prove the point![]()
See how tight it can hold a spring onionCould be a job for doubleboost for the next Sunday night night cap
