robert hardman
- manchester england
just looked at that footage was that on low also noticed that you made contacthave you actually tried to cut with just low on only before switching it to high ?
so what lights do you see on your set
a vid on youtube
extra info
Serial No. 10236/89.Capacity 40 AMPS.Thickness of Cut.8MM.Plasma Duty Cycle.40 AMPS @ 30% OR 25 AMPS @ 70%.Input.240/1/50 AC.Fitted with.TORCH, LEADS
with tip to metal ,
anyway about this lights green light power on
then trigger on gun is pressed some times air will jet through tip and orange light comes on
if i give the gun a tap it will go to red when pressed and fire up on contact
i have tryed it high and low.
do you recon that the gun is faulty its got a mind of its own
i have already look at main high and low switch inside to check contacts all ok
checked all pcb boards and caps for leaks all look ok .
so its back to gun what do you think
and thanks for your time and info
