I have a broken genny, the coils are melted, so from that point of view it is scrap. I will be attempting to take the armature from the motor taper shaft, looks like the two preferred methods are dead blow hammer, or tap a hole in the end of the armature shaft and use a bolt on a pusher to separate it. I may just go for the latter if I have a suitable tap to fit.
Just wondering which others have had success with?
I am also trying to use the old armature shaft, so wonder how easy it may be to remove the coils and iron sections to get back to the shaft, I have use of my lathe, just wondering if anyone else has done it?
The generator is a cheap 2800 Watt type aluminium windings with a Honda copy engine 6.5 HP style.
The engine seems to run OK, it will get a change of oil, but that is it.
Adrian
Adrian
, may see you in the next fortnight if you are up for a visit (either way)
