- SW Scotland
I've got a small fuel tank (~1L) with a leak from an otherwise spot on Briggs and Stratton 35 classic engine. As you can see from the pictures it's had a bash from something and that has deformed the rolled lip seal. Someone has had a go at sealing it with some epoxy putty and it's not worked.
I've brazed with OA before and I'm confident soldering and can do a little bit of leading but I've never brazed with TIG before. I see there's a few formulations of rod, which would be suggested for the tank here? Bottom is mild steel and top is alloy of some description.
Other than the very obvious safety issues are there any caveats to be aware of? Is there likely to be a sealer in that seam?
I'm intending to just run a bead round the whole perimeter of the fold as that's the only place that it's leaking from.
