Whilst it seems re-bar seems to be the choice of sacrificial anodes, surely a brake disc has a greater surface area and as such can actually make it a more efficient process, and a large worn out brake disc is easier to come by and cheaper
) The tank is outside on a handy height wooden bench with the charger & cables running out the garage on it . If it works I'll take some photos for I have a novel way of placing the electrodes around the cut down 310 litre barrel's edge .
Moment of madness 2x V8 Daimler heads in carbon cleaner not a good result How right you areMoment of madness 2x V8 Daimler heads in carbon cleaner not a good result
"As for Aluminium. Be careful and only leave it for a few tens of minutes at a time. You never know the precise alloy and you may end up simply dissolving the work piece! There's every chance you will destroy any smooth surfaces or fine edges anyway. Aluminium is a very soft metal once you remove the oxide layer and electrolysis really isn't a recommended process especially for valuable parts."
Can you use something that large....I have one of thoseSome months ago one of the local DIY sheds was selling off exceptionally large rectangular black plastic water containers.
Can't recall excact capacity but I recall making a mental note they where big enough for a Land Rover wheel or a man sized engine block.
Can you use something that large....I have one of those![]()
If I use a battery charger how could I limit the current? ( Its about a 5A charger)
I made a 'bulb box' with 5 and 21W bulbs and rescued switches
Mount a frame over the box to keep your MMA rods damp free?![]()
