austinmetro
New Member
- York
Only going to be used for car repairs, but unsure which machine?
read a lot of good things about the GYS 162
i looked heavily into the 162 and i cant see anything wrong with it really, the 142 is probably fine but the 162 is still cheap for a mig and has a good rep, plus that little bit more grunt for anything that might need it...
planning on just doing body work is fine until you need to weld up something like a bracket or repair a chassis rail
Is it not very good on the thicker stuff then? Might have to do some chassis repairs as well as general bodywork
the 162 will be better than the 142 on thicker stuff because it has more amps to give...rule of thumb is 1 thouh of thickness needs 1 amp, so the 160 theretically can weld 4mm at full whack, the 142 would still be capable of 3.5mm but the duty cycle would also suffer on a smaller unit.
It's all very well saying 3/4 mm will be the max you will go to but doing it regularly or for long runs you'll be battering its duty cycle.
