Rig Pig
- Narrwich! U.K.
you are actually better having more caps of a smaller size to make up the large value that you want, because they each charge and discharge quicker. That therefore makes the setup more efficient.
But you havn't got one 'hose' each cap is connected separately, therefore lessening the resistance to and from and the inherent internal resistance in each cap ?? and heat build up in the capacitors system overall, a little like having ten battery chargers each charging a small battery, if the ten batteries where connected parralel to one charger it would take longer to charge them.I was thinking along the lines that if you have 1 hose delivering 1 gallon a minute it takes 10 minutes to fill 10 1 gall jars and 10 mins to fill a 10 gall bucket. Which is nearer what we have in a welder, the ripple current available to be absorbed by the capacitors is the same no matter how many capacitors you have. It's the total capacitance that matters.
Electrolytic capacitors do have internal inductance, but I don't know if that depends on the capacitance but I reckon it wouldn't be a problem at 50/100 Hz ripple. Sometimes you see a paper capacitor connected across an electrolytic to filter out high frequencies & spikes the former can't pass.
In higher power welding systems, a single capacitor may be insufficient to smooth the output voltage because the capacitor does not have any limitation on current other than its own equivalent series resistance (ESR). As a result, the capacitor may generate a substantial amount of heat as it charges and discharges during the welding process. To dissipate the heat generated, a bank of multiple capacitors is typically used to share the load. Unfortunately, the bank of capacitors adds to the cost, size, and complexity of the welding system. Since the output capacitor is coupled directly across the rectifier, the charging current flowing into the capacitor from the transformer via the rectifier is only limited by the impedance of the AC source providing power to the transformer along with the impedance of the transformer, the internal resistance of the capacitor, the impedance of the rectifier and other components inherent in the circuit. In general, it is desirable to minimize these inherent impedances and resistances in the circuit to minimize losses that cause heating and reduce overall efficiency and capacity of the welding system. Thus, the peak charging current may be of substantial magnitude and may result in a substantial RMS ripple current flowing in the capacitor. The internal losses within the capacitor and thus the internal heating may be directly related to the RMS current flowing in the capacitor. As the current increases, the heating may become substantial.
but then it splits into smaller hoses where the caps are connected.
But they are by the mere fact EACH is connected and that is the 'multiple hose'The capacitors aren't connected separately, they are interconnected, so in effect you do have one 'hose'.
OK maybe that was not the best analogy, but it is a fact smaller batteries charge faster and if you have lots of them the max capacity is gained quicker and better for the batteries by having multiple chargers than one big battery and charger hence, why you run a slow equalizer charge every now and again.The battery and charger analogy I believe to be false.
They also don't have individual connections,
I did admit that the batteries are not the best analogy, If you took the time to read what I have written that is what I have said.given the same available charging current an array of small batteries will take 'about' the same time to charge as one big one of equal capacity.
That my view of it anyway
What made you decide the caps needed replacing?
Look at the size of those terminals they are huge, are they double ended ie a terminal at either end ?, that would be so that the plates act as heat sinks to rid the system of unwanted and restrictive heat build up.The welder power seemed to have dropped, when I opened it up I spotted this. I found a nasty looking corroded joint in the output as well.
