slim_boy_fat
- Scottish Highlands
Good thinking, I'll measure the tank recess and report back.
What printer cutter do you have roland or mimaki?Is the original silver? I thought it was white.
I have a printer cutter and laminator from a failed business venture, mainly gets used for projects with the kids. I'd happily run a few of these off.
Problem is none of us know what the red looks like other than slim. I have looked at it on 4 machines here and every one is a different shade..lolOk changed the white to silver/grey when people say silver i think metallic cant do metallic.
Like i said earlier bit worried about the red colour match one option would be to cut the letters and circle out.
@dazza : You were right the sticker has taken a beating and deformed. The tank recess is actually 20cm x 4.5cm, so can we proceed accordingly?
Let me know what I'll owe you for materials & postage etc?
I have a roland BN-20 and an easy mount laminator. The printer hardly gets used which causes the head to dry out. Recently replaced the head which was not cheap. I try and run it every now and then but forget.What printer cutter do you have roland or mimaki?
I'm not sure how accurate the roland printer is but i could use a pantone colour in the design you never know it might get close.Problem is none of us know what the red looks like other than slim. I have looked at it on 4 machines here and every one is a different shade..lol
I think postage should be €2.40 depending on what size envelope i can fit it in. I have plenty of vinyl floating about.
And you want it dead on 200mm x 45mm?.....
whats this a concours lawnmower![]()
Plus, it's my OCD kicking in
You've inherited some nice stuff there Slim, cherish them.
Brilliant far better than I could have done. (Without a lot of work)@slim_boy_fat the stickers are done.
I laminated them which should keep them looking top notch for a while.
Did a test fit on the bench.
Fill a spray bottle with water and a drop of fairy liquid spray the glue side of the sticker and the tank this will allow you to slide it to the correct position then squeegee out the water. Or just stick it on and hope for the best.
Like i've been told a few times on here having the correct tool for the job helps. Hopefully my new welder will arrive soon and i can crack on and make a better table for the printer. The one i have now wobbles slightly and it affects the print quality in certain areas. (I have OCD).
