brightspark
- yarm stockton on tees
a drill will never drill a round hole they will be all slightly oval. as above a reamer will produce a perfect round hole
Two, actuallyHole in one.
Wire stripper I assume ??I got the holes drilled today, it was mutch less complicated than I expected.
First I dowel'd and bolted the 2 pices together then skimed each side to give a nice flat surface to work from:
Next I centre drilled, pilot and drilled each hole, and it didn't seem as though it was 2 pices of metal, very happy.
once faced they are easy to work on, good shell mill there.
you need to tram that head a bit better tho.
. I may slide the head off a bit and make sure the marring faces are clean as it Dosent seem to stay put.
