the snooper
getting older by the day
- Hull UK
the sound is created in the voice coil then transmitted to the air via the diaphragm so different materials will create a different soundIt does that by moving the air though!
The electrical energy in the voice coil makes the whole unit move in sympathy with the signal. That in effect "makes waves" by stirring the air in sympathy. It is those "waves of air" that stimulates the sensors in your ears to hear it. This is why there is no sound in a vacuum. (Until 'indoors gets the Henry out at least.)
yes correct t but the material still effects how it's transmitted to the air, which is why they don't opt for paper diaphragms in compression drivers and alike I think we are going to have to agree to disagree
The density of materials is very important, and is the same with cabinet constructionIf it was all about stiffness and the material didn't affect the sound then all these woofer cones would be stamped out of aluminium instead of all the exotics they are using now.
http://www.audioholics.com/loudspeaker-design/loudspeaker-drivers/diaphragm-material
One of those debates, which had been raging for decades, is about metal vs. paper or cloth diaphragms. Each has its merits, and everyone it seems, has their preferences. Let's discuss the basic function of the loudspeaker, and how the diaphragm is supposed to function, and what is actually happening in the “real world”.
An ideal loudspeaker diaphragm would never flex, thus it would exhibit perfect pistonic motion. It would always be infinitely rigid, well damped, and inherently in that characteristic, the speed of sound through the material would be infinite, thus the mass would ideally be zero and the break up mode frequency would be infinity. Loudspeaker engineers have a word for this ideal cone material. Unobtainium (apologies to James Cameron from Avatar).
Audio technology and peoples ears very rarely "ideal".
But people still spend shedloads on their car stereos and that in a noisy environment.
You of all people Wozzaaah know we only need a snippit for a full on debateWow!! Who knew my dying speakers could provoke such lively debate?
To get something worth having I think you will need to spend more the 20 quid on each driver the drivers you posted were 88db efficiency to get another 3db you would need to add another 50 watts, some drivers will produce 101db using the same powerWow!! Who knew my dying speakers could provoke such lively debate?
TBF they are generally spending on an improvement and volume. Audiophile audio in a motor is just stupid.
Look on ebay for a second-hand set with decent drivers it will be cheaper than messing around with drivers that were never meant for the enclosure.
Realistically though I would advise to get some second hand mission 780 or 780se (if you like the mission sound) as they are far better and the last missions made in England. Just make sure they have had updated drivers fitted - preferably the second gen French ones not the Chinese ones from IAG factory.
When I say 780/780se I'm talking the year 2000's on model (not the really old ones confusing as they repeated numbers). And avoid stuff after like the 790 series = a bit pants and made in China
