C
Chris Stevens
Guest
From experience it's very difficult to produce a decent flare on a steel brake pipe using a hand held flaring tool, especially doing a double flare. By time you mess around trying to make a decent joint you would have the full line made up in kunifer with less joints and a lot neater. The kunifer pipe is cheap so it's not too expensive to run new lines from the rear hub to the master cylinder or abs unit. I don't bother joining onto steel pipe any more, too much hassle.
You might find when you start cutting back the steel pipe that it's corroded everywhere under the plastic coating so it will need replaced anyway.
BTW - use a pipe cutter & not a hacksaw to cut the pipe, it leaves a square edge for the flaring tool. You might have to deburr the hole in the copper pipe to allow the flaring tool to fit inside the pipe. I use a small drill bit.
Exactly right. Tried it in the past, and it was major hassle.
