M
Member 66061
Guest
Here is a test using ethernet, not wireless. Not much difference.Yes, its rubbish
Im getting infinity fibre optic next month, ill show another test here when i get it
it is cable virgin mediaLooks reasonable, Definitely above average for ADSL. Cable has much higher speeds.
Mines not too bad, its virgin fibre, Barlidge, 207 meg, you're just showing off
as early as thatCome back with the results next week?![]()
and me comps new with hardly owt on it
thanks for info il do thatMight be worth having a chat with them as their latest base package is up to 50Mb now. Sometimes the signal strength needs adjusting at the cabinet.
It depends on what equipment each provider has in the exchange. We have been upgrading NHS sites that are still on copper and by changing providers we have been getting increases of more than double.If you are still on copper wires, and have low speed connection, changing provider isnt likely to change things an awful lot.
ping is the time taken for your signal to reach the host then back to you againPing (whatever that is) 56m/s
Download 40.55
Upload 9
Ours if FTC.
It has its ups and downs, few teething problems, but mostly okay now.
I'm told to get a more accurate speed check, ideally you'd be plugged in rather than working wireless.
how did you manage thatBT Copper Into House Forget ISP ! Doh!
1 x PC Into Router Into Wall Socket.
Ping = 26 ms
Down = 11.50 Mbps
Up = 0.94 Mbps
Does For My Needs.
M
ive just checked my mobile, 3G been having problems with transmitter, I began speed test and it came back with an appointment in November to view the results
