Pete.
- Kent, UK
Plastic dustbin on floor, hippo pump in the bin. Spray-glue a strip of poly to the wall and drape into the bin to keep constantly re-using 20 gallons of water.
You're reasoning is all wrong about the bit size. A 250mm bit requires a lot more power than a 22mm. The 22 will typically be driven by a small high-speed motor of about 1000w. The 250 is 11 times the diameter but you'll only have 3.5kw to drive it with unless you have a 3 phase supply, so 11 times the cutting area but only 3.5 times the power to drive the drill.
- diamond drillers hate them - we have Weka drills - dogs danglies.
