the snooper
getting older by the day
- Hull UK
that will be 2 huge diamonds hire for the day, what was the delivery addressshall call HSS and find out the weekend rates on that![]()
How muchthat will be 2 huge diamonds hire for the day, what was the delivery address
I think you need 7 dwarfs don't you ? I'm sure they dig for diamondsHow much,erm i'll go with BFH and bolster first,try that and get back to ya
Who needs steel reinforcement when you can do the same as the Taiwanese as can be shown in the pictures of the recent building collapse -
That's right - old cooking oil cans !
what was the local area known as, tin can alleyWho needs steel reinforcement when you can do the same as the Taiwanese as can be shown in the pictures of the recent building collapse -
When I was still working (at a steelworks) we had a specialist firm come into core drill some reinforced concrete approx 18" thick. They chain drilled the wall to allow the installation of a 36" dia gas main. The gear was water cooled & the rebar in the wall seemed to cause them no problems, the ends were clearly visible in the bored holes.Now i dont want this to get into the they did right or wrong,whats done is done as far as i'm concerned
One thing that has me bugged is,if that concrete was so called re-enforced ie has some rather large lumps of steel(rebar) in it,what core bit did they use?
Now i've use diamond core bits quite a few times in my life times(both dry and wet,but not as big as that i may add) and from those experiences i know that as soon as you start hitting metal they soon lose cutting ie the edges wear out very fast esp if you go on the thickest of what they drilled,400mm thick wasn't it?
Ok lets say they did it dry as in no coolant whatsoever,aren't we looking at some mother of a core bit being used here,even if wet,so the report says was used,at that thickness and with,if any,steel in the way thats some amount of water used,agreed?
Yet you look at the so called photos after the job, place has no signs of flooding,you dont see any signs of steel in the holes that were cut just clean concrete,ok perhaps there was a big clean up afterwards who knows.
So to sum up is there a diamond core bit thats that good you can hire out of the local HSS (cant remember if it was hired or bought) that'll go through concrete and steel?
Bazil? ????I do this for a living. Those three holes are about 6 hours work for a competent driller.
Yep, you can easily have a 500 thick wall with no rebar in fact last Saturday I drilled a 150mm diameter 850mm deep in one such wall only took an hour or so. That wall in the pic is very old concrete and construction methods, the aggregate content is very low density and little or no rebar (which again is common for the tpye and location). Piece of cake to put a 250 hole through it and I could show you enough of the basics in 20 minutes that you could do it yourself. Stuff is easy to hire and the bits are standard off the shelf items. They did use water (because you have to) but not enough of it if bit life would be a consideration (which of course it wasn't for them).
Bazil? ????![]()
