malcolm
& Clementine the Cat
- Bedford UK
Transformer?????Inverter?????? aaaaaaaaaaaaargh!!!!
heh, AC/DC is a rock band right?
HELP!! can you explain the difference Shenion? pleeeaaaassse?![]()
I'm sure Shenion did explain it a couple of threads ago. Working from memory -transformers are great heaps of copper wire wound around a big bit of steel. When the electricity goes backwards and forwards through the copper wire it makes a magnetic field in the bit of steel. If you wind another big coil of wire around the steel a different number of times it converts the magnetic field back into electricity but a different voltage as the number of turns is different. The switches on the front of the welder pick up at different points on the second coil, so you effectively change the number of windings and get different voltages out for each switch.
AC is what you get out of the mains supply. Electrons go backwards and forwards all the time. In DC the electrons go in one direction only. Better for welding unless you are messing with aluminium using a TIG set.
Invertor welders are made from magic. Lots of little electrical magic components inside do all the same stuff that transformer based welders do. They are a lot lighter and you can do anything with them, but there's more to go wrong as magic is so much more complicated.
Think that was the gist.
