cumbriasteve
Moderator
- Cumbria UK
I understand DC's (dciron) will deliver purchases over £50 in value for free. .
£200
A self colour nut was welded to the outside and then re taped after galvanising.
Cheers for the formula Wendelspanswick
How I worked out the spacing was to mark the centre of the gate and then have the scrolls all equal length and meet in the centre. Then marked 50mm either side of centre for the verticals railings and then 100mm from then on outwards so the spacing between all the railings is 100mm except for the railing at each end of the gate which turned out approx. 40mm from the end of the gate.
Middle one points down top and bottom.upwhats the point in using 3 hinges. the one in the - middle is in a neutral point and doing nothing. top one in tension and bottom under compression
