BrokenBiker
- Newport, South Wales
Girl over the road rang me in work today of my mrs phone asking advice about electrics, everytime she used the washing machine the rcd for downstairs sockets would trip.
pretty standard advice...stop using it until i can have a look later...
get home and she is outside having a fag and said that after she spoke to me she noticed a burning smell so she panicked and turned the breaker off for the sockets becasue she thought it was going to catch fire.
well i go in and first port of call is the washer, turn it on, wait a few seconds and sure enough, off goes the rcd. reset it all, pull the washer out to unplug it and notice its hardwired...she had no idea it had been hardwired and i cant think of any reason why you would hardwire a washer...
pull it out a bit further and notice it is just choc blocked in a back box with a blanking plate over it...then i notice its wired into a length of 6mm twin and earth...started to worry a bit at this point, traced cable back to CU and found it to be on a 40! amp mcb...
out of sheer curiosity i wanted to know what current it was actually pulling, so clamp meter at the ready i turned it on again and at the point it tripped the rcd it was pulling 37 amps...
needless to say i have disconected it and made safe but i am really struggling to understand why anyone (apparently fully qualified leccies) would runa drop of 6mm on a 40amp mcb for a washer, and then cut the plug off the washer and choc block it together...there is a 13 amp fuse in the plug for a reason and this could have easily led to a fire...
she is fuming to say the least and is going to be telling her landlord she wants it sorted (by me, so she knows its done properly) and wants the name of the people that did the work in the first place
but my point was that not everything has an internal fuse and some that do only have them on the pcb to protect the pcb ive never seen an internal fuse on our washing machines when ive had cause to repair them, same with tumblr dryers
