The other advantage is a very slight theft deterrent...
Because not everyone has a pin hitch, there's that tiny chance they won't be able to just hitch up your trailer![]()
Hi, yes, as I understand it's so the load is only on the pin one way. If it was both pulling and pushing it would promote metal fatigue much quicker and because the pin has a tolerance in the hole of the jaws it would also increase wear. I was surprised as you are at first when I was told it years ago.
Colin
Can someone explain why the braking load should come against the jaw and not be borne by the pin?
I think that most agricultural stuff has all the forces on the pin...
Sometimes, Usually they use a phosphor bronze or oillite bush and pin but like you say they are a good fit so no lash, plus hydraulic rams are slow in comparison to a trailer ring thrashing fore and aft.Aren't hydraulic cylinder ends usually rose jointed to avoid the hammer action experienced by a the sloppy fit found on towing rings?
None that I have used ever has.
