well as the gun is in its slip and im about to get in the car to go out for the night i am going to give the clip idea a go tomorrow while SWMBO is at work (she only moans when i play with guns) and see what i can come up with
Drill two small holes in stock & epoxy in two small neodymium magnets. Add a small metal plate to the switch & jobs done.
Or router a rebate for an engraved metal plate in the stock & fit the magnets to the switch. The engraving is so it does not look odd having a metal plate in the stock.
daft idea but could you use a pir off some cheap leds they are tiny, so that when close to you it switches on, but put it down it switches off !!
BB- any chance of you coming over here for a few days? A mink has reduced out flock of hens from 7 to 4 so he needs 'sorting out' before they're all gone.![]()
Actually what is wrong with a switch on the torch rather than on a flylead ?
Where are you?
He's in Ireland.
Plus one for this. I thought about this whilst reading the first page but carried on reading to see what else had been suggested.Some type of spring clip type bracket? Sounds a good idea. It'd be simple to line it with rubber to stop it marking the wood.
