Hi,
I have a couple of tailgate hinge brackets to weld to a Land Rover rear crossmember. The crossmember is about 2mm thick and the hinge is 6mm. I will have 2 vertical fillet welds to do one each hinge.
Now on stick welding I was taught to go from bottom to top with a root weld then weave a cap on top of it.
But I have read where some people recomend to weld from top to bottom when using a mig. I imagine it would be quite hard to see the weld pool if welding downwards.
Also would you run a root weld then weave a cap, or just run one pass.
I will be using a Clarke 190 to do this job.
Any help would gratefully be accepted.
Thanks Phil Watson
Thanks Phil Watson
whats the cast number tomorrow??
em em em, mechanicals the same tho? Remember to add the cost off emery for the ickle bits of flux that the hammer misses
