I get what your saying and what I mean is this...get some plate..clean it...cut it up in to sections like in picture. ...then just practice laying flat beads until you can maintain consistency then start joining. ....we are all different in the way we pick things up and learn. ..this method is working for me and might help you....I clean about 11/2inches around where I'm welding both sidea I don't see the point doing something that won't be puddled as it won't be drawn in to the weld.
All above are on 1.5mm steel
You've got a good foundation to build on there but you need to sort a few things before they become bad habits that are hard to get out of.
The welds are unbroken runs of a fairly consistent profile but they have a weld face that is far too wide for the material thickness you are welding, you are also getting undercut on the vertical material face, so your next step needs to be reduce the weld size and get the heat input down considerably.
You now need to concentrate on travelling faster, do not weave the torch and add more filler.
Ones a practice the other was a part we needed. What do you reckon. I need to get more rythem.
My thoughts exactly!Thats not bad. But would suggest you saw test piece in half across the weld, and check the penetration. You need to aim for a narrower weld, with full penetration if at all possible. Best to spend time on simply running bead on plate, which will provide better understanding of controlling heat, that should make joints much easier to do.
40 beads would be far more benificial if they were performed trying to perfect the basics. As I've said a few times now you need to pefect technique in the easiest position (PA)(1G) on a plate before moving on. The pic above I did by showing a certain member some basic techniques of controlling hand movements and maintaining arc length, angle, filler while in the flat position. He's now IMO very competent with a Tig torch performing more complex joints as he's nailed the basics. (No prizes for guessing the member)That's how I feel. It's just getting my eye and hand into it. I need more practice and time. Fortunately I know enough theory to see what's bad. Nice to have someone back up my own thoughts.
Something I need to seriously crack is the muscle memory and being smooth not jerky its all time. And experience I think I've ran less than 40beads it will come Im pleased with my steady progression though. .
Cheers.
Looks nice work Brad.Hi guys, think you've got the wrong end of the stick I put those photos up just as an idea on what sort of size the OP's beads should be on that pipe. I know its not great, but not much you can do when you've only got 1.6mm gas lens bodies and can't keep enough heat in the pool at 100A to flow enough filler.
Here is some of my work, at work, welded with Synchrowave 250dx
