Tinbasherdan
Bodger in chief
- Bolton, England
Gorilla welding, ugly but strongThey miss out the rest of the quote, it's:
"My welding isn't pretty but is strong(er than the filler and fibreglass I was gonna bodge it with)"
) to repair the sills on his HB Viva. When he gave it back I asked if it had done the job but it turned out he'd carved a lump of wood to fit instead and covered it with underseal. Car passed MOT !
That's a joke..it just goes to show what actually goes on .Here's another doozy- someone replaced the floor panels and just covered over the rust on the crossmember with a body panel thickness patch. I didn't drill out those plug welds - it was never welded. The forward edge was just stuck down with mastic. In some ways I'm glad because it made chopping the tin can repair easier. I can understand why MOT inspectors get a bit fussy about repair work in structural areas when people do work like this.
at all the above.
Problems with poorly done repairs on old cars maybe have a lot to do with the fact that the cost of having the repairs carried out properly, is in many cases likely to be more than the car is worth? If a car owner gets quoted say £2k for welding work, there is always going to be someone prepared to do a bodge job for a lot less, and I guess thats the reason there are so many death traps on the road nowadays, some of which are much more dodgy than your car.
As phase 3 stick welderAlways makes me cringe, when a new "member" arrives saying. I have an XYZ car to restore, I have never welded before, What welder do i need.![]()
I learned to weld on a car with a cheapish welder with a few tips from a mate who had done a bit of welding once. You have to start somewhere. On the whole new members posting on here have got halfway there as it shows they want to learn something.
Other forums are for people with the attitude that you have to be a trained professional before even thinking about picking up a welder. This forum is called 'the DIY guide' for a reason.
If you have a rotten car to weld though, where would you suggest starting??Of course you need to start somewhere, just not sure a rotten old car which might be very difficult for a pro with years of experience and the right gear, is the best possible starting point?
If someone gets quoted £2000 for repair work (which is almost certainly going to be bodged to some extent), but finds someone else to do the work for £1200 (more of a bodge obviously), they will almost certainly go for the £1200 job.
To get the work carried out properly to a high standard will cost maybe £4000, and is the reason why so many "classic" cars are improperly repaired.
