yes...look under the wiring cover,they normaly have reverse direction instructions,depending on motor type is only switch over 2 wiresBasic question! Will a single phase induction motor (on wood turning lathe) always run in the same direction or can it be wired/switched to reverse?
So does that mean that it should be possible to have a change over switch for convenient reverse running?
ThanksYes. Use a double pole double throw switch.
