Why not return them and get the right ones?Does anyone have a good source of silicon bronze. Bought some from boc but I can see they are gas rods.
Cheers
They don't stock silcon copper filler. Which I know sounds unlikely. Ho hum.Why not return them and get the right ones?
Pretty much any decent welding supplier should carry the proper siliconcopper or silicon-tin (phosphor
Do you need AC for aluminium bronze brazing?I have a stash of aluminium Bronze rods I reckon 1 maybe 2 tubes of them if you anybody is interested.
They're not fast moving rods and so they dont carry them,They don't stock silcon copper filler. Which I know sounds unlikely. Ho hum.
Pretty much any decent welding supplier should carry the proper siliconcopper or silicon-tin (phosphor bronze, C11 filler wire) TIG wires along with aluminium bronzes that can also be used for TIG brazing. You'll find silicon copper (C9 aka SIFsilcopper no.968) in the Weldequip shop and google will get you some other suppliers if the local BOC shop can't exchange the CZ6 / C2 oxy fuel brazing wire for the right stuff and there's no other local sources
Really, you can TIG braze with pure copper wire? Any special tips and tricks? I'm gonna have to try that.
I'd have thought that welding hardens it. To anneal copper it's heated to dull red and then quenched, the opposite to ferrous materials.I welded copper sheet using ordinary pure electrical copper wire, it worked fine, but the heat of welding anneals the copper, making it a bit weak.
You don't have to quench copper to anneal it, air cooling is fine. Welding it will get it well beyond dull red, then when cooled down it would be annealed.To anneal copper it's heated to dull red and then quenched
quenching only cleans the scale of it thats all. not neededI'd have thought that welding hardens it. To anneal copper it's heated to dull red and then quenched, the opposite to ferrous materials.
