norsa
old school painter
- Newbury UK
Only if A: one is competent with D.A. and B: time is criticalI would 320 dry DA
It can go horribly wrong!
Almost certain its contamination, probably not washing the panel enough before wet and dry. Its my first time spraying , bit nervous of runs so I'm not putting enough paint on and seems not to be fusing into a flat surface. Theres a lot to take into account , skill comes with experience. Thanks for all the advicehave you found out the cause of the marks ?
also if you are getting orange peel texture something is not right ie air pressure, distance, paint viscosity
It can go horribly wrong!![]()
They were just examplesHow do we know how thickly the op is putting the paint on ???
They were just examples![]()
But what i'm getting at is no one knows how thick the OP is putting it on at, A lot of new sprayers often put it on real thin as scared of a run and 3 coats of thin is easy to go through !!!Yep That's meI knew what you meant mateBut what i'm getting at is no one knows how thick the OP is putting it on at, A lot of new sprayers often put it on real thin as scared of a run and 3 coats of thin is easy to go through !!!
