future_jack
I have to keep the new portamig well locked up in the shed so I need to find out what the best locks I can get are within reason.
Look forward to responses.
As Hitch said, disk type padlocks are good and some are 'insurance approved'.
Officially DIY wiring is positively NOT OK for insurance purposes. Unofficially, if the installation was already there before Jan 2006 (or was it 2005) then you don't need to do anything. ie if it looks like it was already there ...
To be honest, you will be OK running the Portamig 185 on an ordinary 3 pin plug for most applications, just not upto it's maximum. Make sure it's a good quality plug though. My blue 16 amp plug and socket are still on the bench awaiting fitting, and I believe a few others are in the same situation (Malcolm?).
Just checked out that on youtube, did you see the size of the bolt cutters and cable cutters he had?
Nothing is secure, theres always a way of getting round it.
Theres little thats a match for a gas torch or a cordless grinder![]()
Hello Future Jack, forget the locks and chains, they cost a fortune and are easily cut by the welder you want to protect. Go to poundland or your local hobbyshop and buy a p.i.r. operated sounder and fit it to the shed. There are some really cheap, very loud, units around nowadays, with a coded keypad that will work on a 9 volt alkaline battery. All my sheds and tiny workshop are fitted with second hand alarm systems, the 4 channel variety that are no longer used in households nowadays, 2 of them are key operated, the other 2 have keypads. I get them gratis from a friend who owns a skip yard and they come out of the recycling bins. The keyed ones had no keys but changing the lock is simple and they are only £2.50 each. The coded ones I decode and reset with new codes, its not rocket science to do. I get all this plus a choice of anything that comes on site as part of the reason that I do work for him, the wages come in handy too now that I am retired. I have a welder/fabricaters paradise to work at, I have metal stocks most newbies could only dream of including yards of screwed rod, tubing, square section, c channel, rsj, ali' steel plate etc. The beauty of it is he loves me for taking it as he saves on the super high landfill fees we have to pay down here. I built myself a wood burning stove for the lounge and he supplies the timber, I built a waste oil burner for my little workshop, he supplies all the waste oil I could ever use plus some diesel from the plant equipment. I only use the central heating for the winter months then only need it on low. So visit your local skip yard or second hand shop and you will get the alarms you need for a pittance. I hope this helps you, Bob. p.s. I wired in a pensioners wireless transmitter to my top shed, where I keep my old motorcycles, the transmitter is fitted in the bedroom so I can sleep soundly at night. (yes it came out of a skip).
