so a 12v car battery charger will work fine for this ?
What are you going to use this table for anyway ?
, I want to be able to do small milling jobs on my bench drill press if I can [not ideal, I know], and if for example I need to set out accurate holes in backplates etc.
] also has to house the tumble dryer, my lathe, a router table, Bench drill press, small bandsaw, benchtop mortiser, new welder + gas bottle, wood stock, metal stock, folding steps, workmate type table, lawnmower, sundry gardening equipment, 2 walls of kitchen cabinets/worktops, pressure(s), car cleaning materials and on, and on and on.......
I actually prefer that finish. So, I big thumbs up for the process, I'll be designing a Mk11 version to improve efficiency and to make it easier than faffing about with hanging bits off wires [think, magnets and metal hooks
Yes....
What are you going to use this table for anyway ? I have one twice the size and find that too small for much work. When you start wanting to cut large radiuses on parts and need to have room for clamping, you run out room very quickly.
not a good ideal to use a drill press for a mill.
I realise it's less than ideal, but used bench-top milling machines are few and far between up here - the Seller of the rotary table had one and I missed it by one bid.![]()
This was my setup and result
] opening up.......
So you have a lathe?
, but I do have a pal with a Colchester Student....food for thought. I've been under the impression that milling required higher spindle speeds?This was my setup and result
that looks good, might have to give it a try out. how long was it in the bucket for..... ms08 ?
i have a battery charger, bucket or container, scrap metal and copper wire etc.
so what stuff is it you add to the water.
Can you only go up and down with that one in the video ?
