Erm! 'washing soda'? shouldn't that be Caustic soda? you'd be better off with fairy liquid.![]()
So are you just using a standard 2-3 volt battery charger like I have in my garage for the racing batteries?
I have been doing it recently to clean bits for my 9000......give a good dose of washing soda, I also start with warm water to dissolve it.......negative to the item iirr and positive to the return. I used two lengths of rebar 180 degrees apart and linked together with wire..make sure that you have good continuity with a meter..battery charger on trickle and leave for 12 hours or so...start to get an orange froth fairly quickly.....
] or b) increase the number of anodes.
[ #progress Wasn't there a set of loose ball bearings in the bottom rusty groove? That sealed bearing looks a bit small to be taking all the load on its own. My rotary table, although much larger, has a small central bearing for lateral location then a set of loose ball bearings around outer edge under the table to take the vertical load and thrusts from cutting.
Pics of your setup would have helped on the outset ya know.![]()
] Heath Robinson, but the Mk11 will be a thing of beauty
