dam want a 16 amp feed now
whats your point when its an aircooledDrain plug !
How perverse is that!Im just showing you my drain plug![]()
cant think why mind it will never be emptied .after 40 years i checked it and the oil was fine Don't take it out! The air will all pour out!!Drain plug !
had another go tonight easy to start no sticking with this mechine 3.2 rod 112 amps burned it well even melted a piece of 3 mm
i change the cable on the 16 amp to 13 plug converter cable i scraped a cooker and removed the cable to use it its a lot better as the old cable got warm to the touch
thanks angel
that i would like to see
2.5mm max flex in a 13 amp plug
