you still need to get power to the coils on the armature so how can you do away with the carbon brushes, you could have a fixed magnet armature or an electrical armature which requires powerWhat is really meant is electronically commutated dc motor... Where the changing magnetic field is contolled by semiconductors rather than a mechanical brush/ commutator. Two main types - open loop ... Where the field is switched in an arbitrary manner. And closed loop where the shaft position is monitored and the field switched in response. Removing the need for brushes simplifies the mechanical system and allows the motor to run faster.
Either have a permanent magnet armature (simplest), an induction motor armature (with induced field).. or the compromise arrangement of slipring feeding the armature (like a car alternator). In fact there are some marketed systems for converting car alternators into electronically commutated motors.
No. Not garbage. That's pretty much it.So controlled with a VFD then or type of?
Sound a bit like the brush-less DC fans used for cooling CPU's etc. little oscillating circuit switching coils that pull round an armature.
Or am I talking garbage again?
Adrian
You can argue stepper motors are digital. I can see why they'd be used in a scanner but not in a vacuum cleaner.Dyson claim that their Digital Motors are smaller and more powerful than others.
What is a Digital Motor ?
A stepper motor?just read its a fixed magnet with field coils so all that's controlled are the field coils via digital circuitry but still not a digital motor which ever way you look at it
Digital control as mentioned before, but that's not a digital motor, it's a digitally controlled motor.
Dunno, but I suspect it's a totally bogus advertising campaign.
