Google is a great allie for the most obscure bits!Sorry re read your post. Yes your correct it will probably be just the relay or transformer so I could unsolder those from the pcb an solder on new ones - if I can find replacements.
Do you have a Maplins local to you?Morning all
Thanks for all the advice so far. Need some more I'm afraid. I need to replace the relay on the pcb View attachment 63343
I don't suppose anyone has a link , rs number or any idea where I can source one please. ???
Has somebody broken into the plastic case and soldered cables directly to the relay? I've never, ever seen that in close to 40 years of working with electronics - what an unholy bodgeMorning all
You've not looked at the pictures I've posted have you....Have you checked that the transformer on the pcb is putting out 12v dc? The relay might be ok, it might not be getting the 12v to operate it.
If you can't get the exact relay you could get a generic one with a base mount and connect it to the pcb with fly leads. Something like this would do your job and being rated at 40a would be over-engineered.
http://www.ebay.co.uk/itm/1SET-JQX-...-Relay-W-Base-12V-24V-110V-220V-/261617579215
