Bill Edwards
 - Scarborough, North Yorkshire
I've replaced several injector pipes on our 6cyl cummings crane engine with pipes of different lengths and had no ill effects, I was under the impression that it was the injector that opens and closes and as such it doesn't matter how long the connecting pipe is because once its bled the injector will let out what the pump puts in, you don't get a drop due to length, whatever you put in you will get out.
edited to add I don't think we are talking about modern diesel engines here with coded injectors and pump sensors and ecu's. we are talking about proper engines that work.
I agree there's no compressibility in the fuel and you ain't expanding an injector pipe so length should not be a factor for the distances involved.
Sorry, but it really is wrong to have different pipe lengths. And yes, I'm talking about proper/traditional (old) diesels, not modern stuff which is getting past where my knowledge is.
Manufactures go to the trouble of intricate designs to make them all even, it is important. I believe (though I remember the do's and don't better than the theory, it's a while since I studied this stuff) that the issue of different pipe lengths is in the resistance to flow.
I'm not saying you can't change them without noticing the effect, but that doesn't mean you can always get away with it, and it doesn't mean the engine is still working exactly as it should. Fuel injection is very precise.
 I want it to look proffesional so really nervous about it all.
 I did wonder how much it would cost for me to pay someone else to do this like how I'm doing it, I've spent about 4k in parts so far, I think I'm looking at 5k total for all the parts by the time it's done
