 - Never Never Land
Update time
So I did what I could today, realised I'm missing some parts for the front end but put the rear axle on
 I should get a load of my parts tomorrow to put some other bits on maybe fuel tank and fuel lines etc.
Started by bolting the wheels on and fitting the washer I left off the wheel bearings on one side
Don't worry the wheels aren't staying.
Then pulled the chsssis outside
 it looks fab
Tapped out the holes on the spring mounts.
Rolled it under, I will get my new spring wed I think so the old ones will do till then, I didn't bolt the retaining plates on the sprints either, saves time with them off to just switch them over
Looks great anyway
 I once I started on the front axle I realised there was loads of bits im missing which really frustrated me. I'll have to order them tomorrow morning.
Had to put it away without the front axle on. Will try get it on at least tomorrow and final bolt it up whenever I get the couple bolts I'm missing. Can still put the suspension bars and stuff on, may clean and fit fuel tank and other parts tomorrow
 and rear wiring I think
 I should get a load of my parts tomorrow to put some other bits on maybe fuel tank and fuel lines etc. Started by bolting the wheels on and fitting the washer I left off the wheel bearings on one side
 it looks fab Tapped out the holes on the spring mounts.
Looks great anyway
 I once I started on the front axle I realised there was loads of bits im missing which really frustrated me. I'll have to order them tomorrow morning. Had to put it away without the front axle on. Will try get it on at least tomorrow and final bolt it up whenever I get the couple bolts I'm missing. Can still put the suspension bars and stuff on, may clean and fit fuel tank and other parts tomorrow
 I just ordered what I think are the last two things for getting it rolling. Photos later
