only had 51k on the clock... Most of it on the beach!
	I have a 1998 300tdi 110 if you fancy a bit more welding,only had 51k on the clock... Most of it on the beach!
Holy hell!!I have a 1998 300tdi 110 if you fancy a bit more welding,only had 51k on the clock... Most of it on the beach!
 I'll deal with that once I go get some 12point sockets. Tomorrow then
. Then I think I'll paint strip it all and if I've got pain't I'll paint axles as I'm brush painting them.What size pipe clips do you need, I've got a decent selection so may be able to help.The fuel pipe clips, lots of them, £7 each!!!Not even remotly amusing
They are strange things, like an m shape the middle part of the m goes into a push on clip thoughWhat size pipe clips do you need, I've got a decent selection so may be able to help.
What a lovely gestureI've got nothing like the one in the middle, but do have some back-to-back clips like the one on the left, I will measure what I've got if they're of any use.
 thanks. Not sure if I broke any of those. I know I need every single brake pipe clip, need to work out what they look like thoughWonderful idea. I'll be putting wheels back on once done though I've got a full set of brakes and pads too so will fit new disks then just refit wheels and put callipers on when they are rebuiltThese are quite handy for rolling axles around. You can roll the axle right under and bolt up once all painted.
Got a tiny bit done today. Took a load of parts for shot blasting. Didn't get tonnes done but I'm almost ready to paint strip and paint, I've not got any bloody paint yet though!!! I'll be calling them tomorrow morning. Was promised it Tuesday.
£35 to get this all shot blasted. Need to get calliper rebuild kits from somewhere. Saw some on fleebay but I'll try genuine ones.
I got a quote for genuine front callipers was about £360 each, then fears were £160. I don't want Britpart callipers. I'm going to buy after marked bearmache (sp) rebuild kits, works out to be about £50 in total.Hi Kim
I was looking to re-piston and re-seal the four calipers on my 300 TDi Disco this time last year. In the end I didn't bother as the new calipers complete were sooo cheap from this place http://www.ebay.co.uk/itm/DEFENDER-...350?pt=LH_DefaultDomain_3&hash=item1e93efecc6
Their Defender ones are slightly more expensive. New discs, calipers and pads for mine all round was somewhere near the £170 mark as I recall. They've been in use a year now and I have no complaints whatsoever. The trader was really genuine too (first time I'd used them). I collected as was passing one day. Worth considering...
Shaun.
What's outgas ? I need to buy some heat sensitive paint though.And if you are going to paint the calipers, outgas them first or as soon as the calipers get hot the will start to lift the paint. That's why powder coating on such parts is way better.
When I bought my kunifer brake pipe kit from Craddocks it came with lots of clips similar to those on left. Are you going kunifer route or genuine Land Rover made up and coated pipes?
