Thanks guys. I'm very impressed with this thread. I kind of like the whole customisation and hacking thing, but yes, the welder should work fine out of the box!
Was going to try that one first Skotl, just need to get hold of the relay first. Need to pull my board out and see what power the other relay is etc. I have no idea what model or anything I have, apart from its a handymig with minimum 30a, and 4 power settings. The info is corroded off etc
I think for me the issue is every single modification has consequences and sometimes the consequences require other modifications to fix them.......
Wire liner and a brace accross the rollers don't - everthing else does
But I'm not sure that I'd agree that one mod requires another (off the top of my head, but happy to hear your counter-argument!).
Thanks mate. Ended up starting another thread like you suggested.
I'd agreed with you - my post said (or was meant to say, I grant it perhaps didn't read that way) that it "doesn't cost any more to start a new thread". Perhaps tongue in cheek, but my recommendation was defo to start a new thread rather than continue on this one.That's great - the reason I ask (despite skotl's arguement that it doesn't cost anymore to have it in this thread) is because if you put mods into this thread it's gonna end up reading like "groundhog day" over and over again the same process of modifications carried out by different people and TBH this thread is confusing in places to me when I read it back and I wrote most of it......
Welcome to the forumSorry to Necro an old thread but......
Hoping someone is still reading this.
I kinda gave up trying to weld lots of years ago after purchasing a Cosmo 130 which I believe is almost exactly the same setup.
My dad and my brother are/were both coded welders and always bigged up their welding skills.
I am in no way trying to say good welding is anything other than very difficult artistry, but... I always thought that just being able to run a bead without it looking like a dog with bowel issues had run past shouldn’t be too difficult.
I have recently had some time on my hands and some fixes that require welding on my work van (will have to let my brother lord his skills over me if I can’t do a simple weld), mods to my Harley 1992 Sportster not special but if I can weld it could be and sill repairs on an R107 Mercedes 380sl.
I know some of the welding is aspirational and am no way inclined to attempt anything structural. (Sills are structural I believe).
I am electrical by trade and have read and understood everything i have read in this thread.
I have the welder already I have no issue at all with carrying out the mods if they are worthwhile and love the post about about learning the hard way so you understand better how something works.(Driving without a clutch +1 done it myself)
My query is to any of you who has carried out these mods and used other welding machines.
Will I end up with a better machine than I could purchase today for about £300?
...mods to my Harley 1992 Sportster...sill repairs on an R107 Mercedes 380sl...structural...
These include the Static Arc 140, the Uptime 160, and the Blackline 200. These inverter machines have infinitely adjustable variable power output, easy gas/gasless selection, and can also be used as Arc welders ( MMA ). There are reviews on this Forum. Prices range from £160 to £233.Or buy one of the many cheap inverter machines and use it before it breaks.
Had some Vodka too now!These include the Static Arc 140, the Uptime 160, and the Blackline 200. These inverter machines have infinitely adjustable variable power output, easy gas/gasless selection, and can also be used as Arc welders ( MMA ). There are reviews on this Forum. Prices range from £160 to £233.
Kinda. Old transformer welders like an Oxford will last forever. Modern electronics tend to either break in the first six months or go on for years, but it's true that repairing them is likely beyond most hobbyists.Had some Vodka too now!
Do you mean these will break or are you saying these will be better?
I get the idea of manufacturers making machines more cost effective with newer technology but I am not yet convinced complicated circuitry is anywhere near as reliable as wire wound transformers.
Even LED lighting, the LED will invariably outlast the driver (inverter) in my experience so I cannot understand how they are supposedly more cost effective/eco friendly in the long run.
Or more importantly as far as I’m concerned not going to fail when I need them.
(The lighting installations I work on range from 5-10 x 4watt domestic lamps to 12000 x 1KW commercial lamps for horticultural.
Only 1 of the growers I work with has LED because it was a new build, the others won’t convert due to reliability/replacement cost implication issues.
Sorry I may have had more than a bit of vodka.
They will be better in that they offer options and features that don't exist at all on transformer MIGs. For example, you can press a button, plug in an electrode holder, and use them as a stick welder. The inverter output can be changed from constant voltage control ( CV ) for MIG to constant current ( CC ) for Arc. So in the same unit you have a MIG for thin metal and an arc welder for thick plate.Do you mean these will break or are you saying these will be better?
Im a pervert that actually really liked using my little SIP105 for thin bodywork stuff, steel liner, braced roller before id joined this forum then when was looking on the internet for "why has my welder stopped working again" found this forum , then someone came up with the transformer mod and that went in too.
In the end id done so much welding with it it was just second nature whether I was lucky, had sorted the problems or had just learned to compensate i dont know but rarely had a bad day with it.
id found a second hand "proper" welder( linked on this site) for £300 and took a punt but still miss my little 105 now and again.
id not go nuts spending money on a Euro torch etc but a quick 24v independant power supply for the feed motor will keep you going till something better pops up, oh and they weld best on Argoshield light or similar rather than Co2.
Sean
