the snooper
getting older by the day
- Hull UK
what make is your compressor ?not knowing much about them i still dont have a clue what that means but thanks for trying to explain it. I'm sure once the NRV is fitted it will be ok (fingers crossed)
trying to simplify itnot knowing much about them i still dont have a clue what that means but thanks for trying to explain it. I'm sure once the NRV is fitted it will be ok (fingers crossed)
anything like thisits a FIAC compressor, has a clark 3hp motor, no idea if the pump is original so the make is a difficult one really, bit of a mongrel
makes sense now, so as the nrv wasn't fitted the pipe was pressured back to the pump hence why its leaking from the dipstick tube, the unloader valve wasn't even connected as the thin pipe was just laying onto of the receiver, it will be reconnected though once the NRV is back on
sounds like the guy you bought it off didn't have a clueyup i remember those reed valves when i changed the head gasket about 18 months ago
I Know what it does and where it is connected,here you go norm, this pic clearly shows the delivery pipe and un loader connection to be one and the same port
It is open to atmosphereIf there is no non return valve, I don't understand why air isnt gushing from the unloader valve as its fully open when the compressor reaches full pressure
on a lot of compressors the un loader line is connected directly to the delivery pipe so if you remove the non return valve it would empty the receiver through the un loader valve, I know you say it cant if its not there which is obvious but we were trying to work out what was and wasn't connectedI Know what it does and where it is connected,
but if it not there it cant leak !! neither would the line from the pressure switch because there is NO feed from the switch the unloader line goes TO the pressure switch and is relieved by the pressure switch.
I dont know how that has lasted, I have seen multi wire hyd hose melted bv by the air from the head before now.nope was a rubber one
depends on just how good the compression is I suppose and heat generatedI dont know how that has lasted, I have seen multi wire hyd hose melted bv by the air from the head before now.
Discharge and Distribution Piping
Here we have more complex considerations:
The discharge air from the compressors can be at 250 •F to 350 •F (for centrifugal, oil-free rotary screw and reciprocating types), or from 200 •F to 220 •F (for lubricant-cooled rotary screw compressors), so the pipe must be able to withstand those temperatures.
