SmartWerks
pre-moderated
- chester
I'm needing to buy a fair bit of copper piping, 15mm stuff. Where is the best place to source?
I'm making a air line system for the shop, am I best using soldered joints or compression joints?
I am making 2 systems, one for the powder gun running from me lil oil less compressor into a dedicated room for masking, coating and curing. and the other from my main compressor to run air tools and pressure pot in my dirty room. I have enough 10mm piping and bender so i am thinking of using that for the system from the oil less to run the powder gun as it doesn't require much air at all. Any Problems using 10mm?
This is the sort of layout I'm going for
http://www.hotrodders.com/forum/home-c-coil-air-compressor-air-dryer-227480.html#post1629191
HOSE THAT IS
. The stuff at the wood yard is like large bore plastic water fittings, it's fast to install, leak free, and importantly quick to modify. I've also used domestic for a install in workshop I had a few yrs ago, testing it for my house.
