Wallace
- Staines, Middlesex, England.
PWM ???
Pulse Width Modulator as optima21 posted above, gives a variable pulsed frequency to the motor allowing speed control.
PWM ???
I've been doing quite a few 3/4" diameter beads in 1.5mm steel sheet lately,
can see why a powered version is desirable, i've got the strength of Shwartznegger now![]()
That always happens it would bug me to. The winch works well it is nice and slow and with the foot pedal it stops immediately which is another thing you have to think about with g/box it may run down after supply is interrupted which you do not want.annoyingly I gave one away a few weeks ago that may have been underpowered for what I wanted, and I'd had it for years without using it.
Have seen a small electric drill via gearing being used so it can't be that much power needed just the gearing down that does the work. Mr L30 Think your machine would need lots of power on that ali
